Konia - Minolta 8050 problem
  • captain1976
    • Jul 2008
    • 79
    I have a 8050 that says "operating please wait" This will not go away and the machine will run for hours like that. Any suggestions?
  • kmcopier
    PSP
    • Oct 2008
    • 183
    Check your fuser unit there is maybe an paper stuck on the between the web and upper.
    • captain1976
      • Jul 2008
      • 79
      I will check it out and let you know.
      Captain
      • captain1976
        • Jul 2008
        • 79
        Didn't work
        Fuser looks fine. I even removed the web and everything appears normal
        • Luther
          • May 2006
          • 682
          Are you sure thats the exact message? or is it "copying please wait" or "adjusting please wait"
          • captain1976
            • Jul 2008
            • 79
            Hello,
            Yes, it says "Please Wait" Adjusting and it will not go away. I can get it to print data sheets from the "36" mode but thats it
            • Luther
              • May 2006
              • 682
              Thats usually DMAX adjusting but it usually happens when the machine has been off for more the 6 hours,or every 1000 pages .or even if the humidity has changed at least 30%,sorry thats all i have for you.how long have you let it sit with that message ?
              • captain1976
                • Jul 2008
                • 79
                Hi Luther,
                I got this machine last week and when I tested it out, it read the same thing. Then I turned it off and back on again and it said to replace the yellow toner. I did that and got it to make a few copies but then after turning it on again it will run for hours if I let it and still says its adjusting. There has got to be a specific reason it will not go out of that mode and the manual say nothing.
                • Luther
                  • May 2006
                  • 682
                  Have you checked the other toners?
                  • captain1976
                    • Jul 2008
                    • 79
                    Yes,
                    The other toners are good but since I have new ones in stock I will replace them all and see it it does any good.
                    • random
                      This may be a red herring but on the c6500 if DIPSW 11-1 is set to 1 the error codes are ignored and in a fault situation the machine will do this. Perhaps you should check your handbook for a similar dip-sw.
                      • kmcopier
                        PSP
                        • Oct 2008
                        • 183
                        Start the machine up in 3-6 mode and make some test
