Bizhub 501 Show C-C286 Error Code
  • manzoorwighio
    • Dec 2019
    • 28
    Konica Bizhub 501 Show C-C286 Error Code How to Solve it ?
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Bizhub 501 Show C-C286 Error Code
    C-C286 Non-volatile memory abnormality
    Overall control board (OACB)
    NVRAM board (NRB
    if the nvram has a battery, sutrely it must be dead by now, that an old ass machine.
    NVRAM board (NRB) error code display priority
    When two or more error codes related to NRB occur at the same time, a code with the highest precedence is displayed according to the priorities shown below.
    1. C-C287 → 2. C-C288 → 3. C-C286 → 4. C-C284 → 5. C-C285
    • manzoorwighio
      • Dec 2019
      • 28
      NVRAM board (NRB
      Thanks Your Very Much Sir
      Without replacement of NVRam any solution ?
      • emujo2
        • Mar 2017
        • 1579
        "OACB or NVRAM" If you want to take a chance, try a new battery and firmware.
        • Synthohol
          • 5922
          try a trouble reset yet?
          turn ON the main power switch (SW1).
          2. With the Utility/Counter key pressed, turn ON the power switch (SW2).
          3. Press [Trouble reset] to release a trouble with [OK] displayed.
          4. Turn OFF and ON the power switch (SW2).
