make c454 always print 2 copies
  • cube10025@gmail.com
    • Aug 2022
    • 55
    #16
    Re: make c454 always print 2 copies
    Originally posted by Gift
    What about the V3 driver as suggested by B0265 - sounded lika a good hint to me...It wouldn't be the first feature that got lost with a new driver generation.
    Would be great but V3 driver when used in print manager clients needs admin rights to install.
    • B0265
      • Jan 2007
      • 718
      #17
      Originally posted by femaster
      I can't say that I am the most knowledgeable person when it comes to the print drivers, but does the V4 driver not have the Carbon Copy option? I only ask as the V5 driver we are using with our in-house C654e machine still lists the Carbon Copy option under the "Cover Mode" tab in the print driver. I've never used that function, so I can't offer any advice about it.
      V3/V4 in this case refers to the Microsoft printer driver model, not the actual driver version.
      • Gift
        • Mar 2011
        • 2459
        #18
        What's the problem? Did the customer forget his credentials?
        If I were you I'd check out that driver on your notebook and see if it would accomplish all demands - if you're shure it does you can tell the customer this is your suggestion.
        If they can't install it -> not your problem any more, you already did a lot of "good will" work they should be thankful ybout.
        • B0265
          • Jan 2007
          • 718
          #19
          I think the problem he has is caused by the Microsoft updates to adress the "Print Nightmare" security vulnerability.
          KB5005652โ€”Manage new Point and Print default driver installation behavior (CVE-2021-34481)
          • femaster
            • May 2011
            • 1519
            #20
            Ah, thank you for the clarification on that! I was in fact referring to the driver version. Learned something new today.
