Konica Minolta C458 Humming/Whistle Noise
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C458 Humming/Whistle Noise
    in Konica Minolta C458 getting continuous Humming/Whistle Noise.
    Even the front and side doors are open and machine is not functioning. Is it from power supply? or another card.
    Kindly advise.
    Thanks and kind regards,
    mearmi
  • copyman
    Owner / Technician
    • Sep 2005
    • 4786
    Re: Konica Minolta C458 Humming/Whistle Noise
    Kindly advise.
    mearmi
    Not much is on and little output from power supply with doors open. If happening when doors open then I would look at a fan making noise.
    • Oystercopy
      • Oct 2009
      • 626
      I'm with the previous answer, I've had to replace several fans for noise, down by the power supply. Reasonably easy to get to.
      OC
      • tsbservice
        Field tech
        • 8075
        My vote goes to PS.
        See this thread Bizhub C308 Power Supply Humming Noise - Fuser
        Last poster has some interesting ideas
        • tmmdmmm
          • Apr 2021
          • 173
          Is it similar to a coil whine? 454s had this issue, a board on the upper rear of the machine. I suspect because they were initially designed for 20a but then dropped to 15a, as it only affected the 454s but never fully looked into it. Might be the same for the 458.
