C-3850, says Yellow toner is out, but its not...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys. I went in and disassembled that little board that contacts the chip on the toner cartridge, after replacing several toners in the machine with no luck.
    Tried disconnecting, then formatting the HDD, no dice.
    Thanks in advance,
    OC
  • allan
    RTFM!!
    • 5462
    Re: C-3850, says Yellow toner is out, but its not...
    Does it reset the level indication?
    Does the toner motor run at all?
    Whatever
    • Oystercopy
      • Oct 2009
      • 623
      Nope, none of the above. Yellow toner cartridge says "0" and the machine does not run; goes straight into yellow toner lockout.
      I went into service mode to add toner, which the machine did, but never reset the indication.
      OC
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        the "chip" is just a resistor for region / type identification and a fuse for new article detection.
        When the door is closed there should briefly be voltage present at the fuse and resistance detection pins. Also, is the fuse on the toner blown or not?
        If you see nothing, find out why - is it the harness, connectors or is there nothing all the way back at the board? I have replaced boards for this exact issue too.
        • techsxge
          • Jan 2022
          • 660
          Have had (or currently have) this problem on a Olivetti A4 Machine. My Issue was that it wasnt actual original toner but some rebuilds from a olivetti contractor that also works for KM, 30% of their Chips dont work. Safest bet currently is to have a machine in the workshop and test the toner out before sending it to the customer.
          • Oystercopy
            • Oct 2009
            • 623
            Thanks for all that guys... but after 3 different OEM cartridges, it still would not reset. I'm leaning towards a board to be bad, but with the cost of these things dropping daily, the cost-effectiveness of having a board repaired/replaced becomes almost non-existent.
            OC
            • techsxge
              • Jan 2022
              • 660
              OC
              have you done a firmware update already? That solves a lot of errors for me
              • kingarthur
                • 1385
                use engine dipswitch 5, as a workaround to reset the toner
                • Oystercopy
                  • Oct 2009
                  • 623
                  thanks for that, but the manual doesn't say anything about DS5 other than (it looks like) "03" is the default, where my machine was at "00" as the default.
                  Can you tell me, exactly what setting you change to make it reset the toner indication? And is that specifically for the YELLOW cartridge?
                  • techsxge
                    • Jan 2022
                    • 660
                    I think we are jumping around in a dark corner. Can you please say exactly what the machines says? Does it literally say "Toner Bottle is empty" or does it just not show how much toner is left? Would be helpfull. And while you are at it, make a firmware update. Shit saved me lots of trouble already
                    • Oystercopy
                      • Oct 2009
                      • 623
                      OK, I think I was MORE than clear about what the error and message was... that is, if you properly read what I wrote about the issue. The error was "REPLACE Y TONER CARTRIDGE" and the machine never even tried to initialize,
                      run motors or anything.
                      However, all the F/W was already up to date, at the latest, and had been since I bought the machine and performed those updates. But I re-loaded the latest Controller and Engine anyway, just for giggles. Did nothing.
                      However, tonight I tried the FOURTH toner cartridge, brand new OEM (the others were OEM as well) and the machine took off.. NO IDEA why.. I guess these toner chips are just unreliable as hell and you never know when
                      you're gonna get a bad one.
                      OC
                      • techsxge
                        • Jan 2022
                        • 660
                        OC
                        For me, it looked like it could be emoty cartridge,, no toner recognition or cartridge in the machine but no display on how much is left. All typicall Errors.
                        However, please see what i write in answer #5, it is not like i didnt say this in the beginning.
                        Recently bought OEM are no OEM anymore. They're aftermarket toner with aftermarket chips and this causes known Problems
                        • druid
                          • Feb 2022
                          • 3
                          Go to Engine FW DIPSw and set switch#5
                          1.Turn ON the main power switch and connect the USB memory device to the USB port of the machine.
                          2.Call the Service Mode to the screen.
                          3.Touch [Loadable Driver Download].
                          4.The loadable driver data in the USB memory device is displayed in a list.
                          5.Select the loadable driver data to be downloaded and touch [Excute].
                          6.Touch [OK] to start downloading the loadable driver
                          5 Choice of toner empty recovery mode I.4.25.5 Details of Each Function - Choice of toner empty recovery mode
                          4.25.5Details of Each Function - Choice of toner empty recovery mode
                          (1)Use
                          To perform the auxiliary toner replenishing sequence when the old toner cartridge is replaced after a toner-empty condition.
                          [OFF]: Not performed (default)
                          [ON]: Performed
                          (2)Procedure
                          1.Touch [Service mode], -> [Engine FW DipSW].
                          2.Touch [5], select [ON], and touch [OK].
                          3.Touch [Close] and exit from the Service Mode
