Konica C258 settings problem
  • Gaffers01
    • May 2011
    • 335
    #16
    Re: Konica C258 settings problem
    Its fairly straightforward to do.
    Let me know if you get stuck.
    • ferro10
      • Jun 2015
      • 117
      #17
      Ok thanks it's all quite simple
      Just one question the mktar_A7PU.bat file where do I find it?
      • Gaffers01
        • May 2011
        • 335
        #18
        Usually in the unzipped firmware file along with the FW00? and CW file.
        • ferro10
          • Jun 2015
          • 117
          #19
          OK thank you
          Today I go to the customer and check the front panel cable. If I don't solve, I proceed with the FTP update
          • allan
            RTFM!!
            • 5462
            #20
            Take a couple for USB drives... Had it where it only worked after trying the 3 drive. Strange thing is the drives worked fine on other models but not on the 8 series. 8GB and bigger does work too.
            Whatever
            • ferro10
              • Jun 2015
              • 117
              #21
              thank you all for the help
              the problem was the front USB cable plugged into the wrong port.
              • Oystercopy
                • Oct 2009
                • 623
                #22
                Great that you got it fixed.
                For future reference, KM is now recommending that you NOT USE Windows to format your USB sticks. I've had LOTS of trouble updating F/W on that series machine, for no
                apparent reason, but this software seems to fix it.
                They recommend a different program, which (I assume) formats it in DOS mode.
                Its called HPUSBDISK and I believe you can get it on KM's support site, or just google it.
                OC
