Konica C258 settings problem
  • ferro10
    • Jun 2015
    • 118
    Hello everybody
    I have to update the FW Sata on a Konica C285 for the D011 problem but I can't update.
    1) I insert the key
    2) I turn on the printer with the red button pressed
    3) At the top right on the display the black dot appears
    4) After about 30 seconds the printer starts in normal mode
    Besides this these options in administration mode are not present
    "When [Administrator Settings] -> [Security Settings] -> [USB Connection Permission Setting] -> [External Memory (Service)] -
    > [FW Update] is set to "Restrict", A Message "It is limited by the Administrator." Will Signore, and Update of the Firmware
    Cannot be executed.
    ▪ When [Administrator Settings] -> [Security Settings] -> [FW Update (USB) Perm. Sett.] Is set to "Password Priority", IT
    Requires to Input A Password After Confirming with the Administrator "
    The thing is definitely strange ... do you have any idea of how to solve? Thank you
    I am attaching machines list
  • copyman
    Owner / Technician
    • Sep 2005
    • 4782
    Re: Konica C258 settings problem
    Originally posted by ferro10
    Hello everybody
    1) I insert the key
    Cannot be executed.
    Are you leaving front door open when trying to update firmware? It has to stay open during F/W update
    • ferro10
      • Jun 2015
      • 118
      The door during the update was open
      • femaster
        • May 2011
        • 1525
        These are the typical problems to look for:
        • The USB memory is formatted in FAT32 format.
        • Use a memory device with no more than 32 GB of capacity.
        • Firmware is in the designated folder in the root directory of the USB memory. (C258 = FW0002)
        • Verify correct models firmware is being used.
        • USB memory plugged into USB port on side of control panel.
        • Confirm that the USB cable from front panel is plugged into the correct USB port (labeled "Front Panel") under the access panel in back right of machine.
        • ferro10
          • Jun 2015
          • 118
          • The USB memory is formatted in FAT32 format. yes formatted FAT32
          • Use a memory device with no more than 32 GB of capacity. USB 4gb
          • Firmware is in the designated folder in the root directory of the USB memory. (C258 = FW0002) yes in another C258 always by the same customer works perfectly
          • Verify correct models firmware is being used. Yes it's correct
          • USB memory plugged into USB port on side of control panel. yes
          • Confirm that the USB cable from front panel is plugged into the correct USB port (labeled "Front Panel") under the access panel in back right of machine. I have to check this point well but if I try to print something from the USB port it works.
          • tsbservice
            Field tech
            • 8064
            Which FW versions do you have and with what file(FW) you're trying to update?
            • ferro10
              • Jun 2015
              • 118
              A7PU0Y0-F000-GXX-A8 SATA Recovery Tool for fix C-D011
              The printer mounts the A7PU0Y0-0100-GC1-W4
              • ltdiniz
                Supervisor de Campo
                • Mar 2021
                • 98
                Hello friend!
                Use this program to format your flash drive
                The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
                Because I already caught the case of using the same flash drive in the equipment update sequence and on the 3rd or 4th machine of the error with the same FW and not loading the firmware at startup.
                Do the formatting and then follow the tips above the members who will succeed.
                Good luck!
                CAUSE: Incorrect placement of the front USB cable and/or incorrect procedure to load the firmware.
                SOLUTION: Check the placement of the “Front USB” cable
                • avecosat
                  • Jun 2012
                  • 305
                  you disconnected the hdd? and unset in service mode ?
                  • copier tech
                    • 8215
                    Hello everybody
                    1) I insert the key
                    Cannot be executed.
                    Have a read of this PDF.
                    Bizhub 8 Series SATA Errors..pdf
                    Try other drives I format mine in Windows never had any issues.
                    • ferro10
                      • Jun 2015
                      • 118
                      yes
                      • ferro10
                        • Jun 2015
                        • 118
                        Originally posted by ltdiniz
                        Hello friend!
                        thank you for your suggestion
                        I don't understand why the FW functions are missing in the security menu
                        • ferro10
                          • Jun 2015
                          • 118
                          [ATTACH]54813[/ATTACH]
                          I tried 3 USB of different suppliers
                          • Gaffers01
                            • May 2011
                            • 335
                            Have you tried updating using FTP (filezilla), whenever i've had issues with USB's I used this instead.
                            • ferro10
                              • Jun 2015
                              • 118
                              Thank you for your suggestion
                              Can you tell me the procedure to activate the FTP update?
