C454 cyan prints and hazy text
  • positiveg
    • Jun 2018
    • 299
    Hey there all. Hope all is well. I can't figure out why we are getting prints
    But the text is hazy and then we are getting blue prints especially in the edges.
    Please assist thanks
    Sent from my SM-G780G using Tapatalk
    • 8132
    Re: C454 cyan prints and hazy text
    More information will help.
    What are the image unit, developer & transfer unit life ?
    Are you using genuine Konica Minolta toner ?
    • tsbservice
      Field tech
      • 7975
      If you change C drum with another Y drum what is outcome?
      • positiveg
        • Jun 2018
        • 299
        Will share the life of the toners. Yep Genuine.
        I'll t4y to switch the drums around thanks
        • allan
          RTFM!!
          • 5462
          Any p-codes? Could be a layer issue before the PDF was created? Use Adobe to print from.
          Seen this before and looks like an issue with the document itself.
          Whatever
            • 14512
            Have you cleaned the IDC sensors under the transfer belt?
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              blue on the edge of the sheets is notorious on this model, note that it may not be visible till much later in imperial paper size regions due to the shorter cross direction width of the sheets.
              Developing roller side seals dont do a great job, particularly on the cyan dev units. Cyan toner ends up contaminating the charge section at the same end where the leak starts, and you get fading in that zone. Eventually developer abraids the drum in this area too and you get tough textured cyan marks down that side of the page.
              It is very important to vacuum out the developer suction ports when replacing developing units and vacuum / replace the toner filter. Never let it clog up. I also set the cyan TCR value to -2 (optional)
              When the developing unit has failed, its important to replace it with the drum together at the same time.
              • positiveg
                • Jun 2018
                • 299
                No it happens with all our docs. Whether jog pdf. Text just shows up like that
                • positiveg
                  • Jun 2018
                  • 299
                  Thanks I'll pull the dev and see. But you are right it spills unto the drum and in fact on the mag and yellow drum too.
                  But I'll check the cyan dev unit and let you know plus also change the values
