KonicaMinolta bizhub C200
  • qbert
    • Aug 2025
    Hi all,
    I have a konica bizhub C200, and want to know how to update the firmware. The machine has the eth port, usb and com.
    To upgrade the fw, I need a particular device or can be done through eth?
    Also read about the "C250/252/300 and C352 IU reset" could also work for my model ?
    Last question, i can update my fw with that of C250 or C3xx?
    If you need further details of the machine ask me
    Thanks to all
  • JSC
    Gimp
    • Dec 2006
    • 618
    PDF shows you how to update the main firmware, for the printer firmware you copy it to a CF card the same way but you need to enter the service mode and select firmware up grade. the firmware only works for the bizC200.
    As far as i know you can not reset the IU`s yet.
    The gene pool could use a little chlorine.
    • h4141
      Konica Minolta Bizhub C200
      There are drivers here
      and software update.
      • emujo
        • Jun 2009
        • 3009
        I want to repair my transmission, I am not a trained mechanic and I don't have any manuals or tools. Can someone please send me the instructions so I can attempt this myself? The only person who is going to be happy with this outcome is the factory mechanic who will eventually spend twice the time fixing what I screwed up and charging me double for his time. Why don't you just call a KM tech???? Let me know how much you wind up spending on your flight of fancy. Emujo
        • RRodgers
          • Jun 2009
          • 1947
          /like.
