C-3110, display light out...
  • Oystercopy
    • Oct 2009
    • 578
    I could have sworn I put a post up here about this issue, but maybe not.
    I have several of these where the backlight (control panel) is out. Tried replacing the entire panel with a known, working (light) panel, but it didn't fix it.
    Anyone have any other ideas? I looked through every setting in Admin mode to see if there was something that would turn off the light, but couldn't find it.
    Thanks in advance guys!
    OC
  • Kenny
    • Jun 2009
    • 490
    Re: C-3110, display light out...
    OC
    most likely down to the SSD, i have also had this when the network cable is plugged in causing the display not to turn on
    turned on without network cable and for some reason came on, then just plugged the network cable back in
    • Oystercopy
      • Oct 2009
      • 578
      Thanks for that Kenny... yeah, maybe the SSD, but I've tried with or without network cable; no difference.
      OC
      • copier tech
        • 7874
        OC
        Awful machine especially now they are getting so old.
        I would try the panel ribbon cable these often fail on this POS.
        • Oystercopy
          • Oct 2009
          • 578
          True copier tech... I know they're not a great machine, but they still fit that sweet spot for an all in one desktop, where customers want the features, but not the size.
          So you've had a lot of those ribbon cables fail?
          OC
          • rrrohan
            • Sep 2011
            • 1971
            Just dull or totally blank?
            Sent from my Pixel 4 XL using Tapatalk
            • Oystercopy
              • Oct 2009
              • 578
              Actually, some are just barely lit, while others have no backlight at all ..... strange
              OC
              • copier tech
                • 7874
                OC
                If the panel is dim then most likely the ribbon cable.
                If no display, you've tried a new panel & cable but the device still prints then most likely the MFP board.
                • Oystercopy
                  • Oct 2009
                  • 578
                  Actually CT, I had only tried the panel, not the cable. But I'll try the cable next.
                  OC
