FS-539 eject claw
  • mascan42
    • Oct 2008
    • 487
    FS-539 eject claw
    Does anyone know how to replace one of these things? The customer somehow managed to break it in half, and I really don't feel like spending 3 hours replacing the whole eject unit.
  • suomi
    • Oct 2008
    • 155
    Re: FS-539 eject claw
    Change >>Ejector Unit
      • 23010
      It's 62 minutes, and that's what you'll need to do. You'll get better with practice. =^..^=
      • mascan42
        • Oct 2008
        • 487
        It was easier than I remembered. It's been at least 3 years since I've had to do it, and it doesn't help that they refuse to put it in the manual.
          • 23010
          The options are never covered as well as the base machine. Whomever makes the options never gives any real thought to making them maintainable. =^..^=
          • Cantechman
            • Nov 2008
            • 229
            I'm not trying to highjack your post, but is there an actual written procedure anywhere to remove that ejector unit? I i may have to replace that same part on a FS-537 and it seems to be impossible to find directions on how to replace it.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              replacing that individual part is a bigger job than replacing the eject unit anyway unless you have small surgeon spec hands to work on it in situ its coming out anyway. Plus practice makes perfect as already mentioned it takes no where near 3 hours once you're familiar.
              • splblazer91
                • Jul 2014
                • 204
                30 min job if you have the right size prybar
