Bizhub 958 dark
  • alberto
    • Oct 2011
    • 12
    Bizhub 958 dark
    Run out of ideas on this
    958 pro
    its had a new drum, dev and transfer belt
    test page is perfect but after hundreds or more pages gets darker
    Went back to it today and test page came out with all squares black and image of bird whole square black
    Opened and closed the front door of the machine and everything was back normal again.
    I have been backwards and forwards to this over the last few weeks.
    Very grateful for any suggestions
    Thank you
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: Bizhub 958 dark
    958 pro
    Thank you
    You have the problem in the opening of the AIDC sensor, the mechanism fails and the window does not open for the sensor to read the band, so when opening and closing the door, you force it to do it again and sometimes it works. This is a common error with this model.
    Field technician since 1994
    • alberto
      • Oct 2011
      • 12
      Re: Bizhub 958 dark
      Thank you for fast answer
      sounds very good
      i will try it out tomorrow
      much appreciated 👍
      • Synthohol
        Certified Konica Expert
        • 5897
        Re: Bizhub 958 dark
        run all the gradation adjustments too, it helps!
        • allan
          RTFM!!
          • 5462
          Re: Bizhub 958 dark
          Can you remember if that shows a P-code if the shutter is stuck?
          Whatever
          • tsbservice
            Field tech
            • 8053
            Re: Bizhub 958 dark
            I think it normally should, however not working on this model.
            • alberto
              • Oct 2011
              • 12
              Re: Bizhub 958 dark
              • elmaligno
                • Oct 2009
                • 302
                Re: Bizhub 958 dark
                • worthy
                  • 9
                  hi just wondering if you manage to sort out the issue on your 958? i have one with same issue. it come and goes but was thinking shutter myself as have seen this on some of the colour machines.
                  • alberto
                    • Oct 2011
                    • 12
                    Hello Worthy
                    Yes, i remember that one.
                    I ended up taking the part off a scrap machine
                    Please see attached 958.pdf pic
                    • alberto
                      • Oct 2011
                      • 12
                      pic
                      • worthy
                        • 9
                        Thank you so much for that info that helps loads !
                        cheers
                        Worthy
