enable disable password
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Good morning, I have noticed that there are some C368 series that it is possible to disable the password prompt when entering service mode. But there are others that do not, the corresponding button is blank. Does anyone know how to enable this button to make it ask for the password or not?
    Thanks.
    Field technician since 1994
  • techsxge
    • Jan 2022
    • 660
    Re: enable disable password
    Different Firmware as far as i remember. Never used that function because i just have CE Password enabled all the time
    • elmaligno
      • Oct 2009
      • 302
      With the same FW I get different results. It's probably a dip switch.
      • techsxge
        • Jan 2022
        • 660
        Could be. Or is it maybe HDD not installed?
        • elmaligno
          • Oct 2009
          • 302
          No, same configuration.
          • techsxge
            • Jan 2022
            • 660
            This is what i found
            • Synthohol
              Certified Konica Expert
              • 5898
              4, 8, i all the same way.
              stop 0 clear
              • elmaligno
                • Oct 2009
                • 302
                stop 0 clear
                I know, the thing is that sometimes that key appears and sometimes it doesn't, that's the reason for my question.
                • elmaligno
                  • Oct 2009
                  • 302
                  [ATTACH=CONFIG]54970[/ATTACH]
                  That was the solution. Thank you very much mate
                  • techsxge
                    • Jan 2022
                    • 660
                    Just FYI this is easy to find if you have the service manual and search for CE Password. Open service manual in browser and press ctrl + F to open search
                    • Synthohol
                      • 5898
                      totally misread/understood, my apologies.
                      • tsbservice
                        Field tech
                        • 8054
                        Imho it's always bad idea to disable CE password. For example tech can't setup remote panel.
                        Better change it to something short if you're constantly tired to input default but leave it.
                        • techsxge
                          • Jan 2022
                          • 660
                          There is almost no scenario where disabling the CE Password is like a good idea. Realy, there is no world where this is good.
