C6000 corrugated paper
  • Konica C6000
    • Oct 2022
    • 9
    Hello!
    I have a Konica C6000 machine and when printing 80gr paper, the paper becomes wavy. What might be the problem?
    Thanks in advance for your help.
  • tulintron
    • Jul 2014
    • 668
    Re: C6000 corrugated paper
    Good Morning. Check the fuser unit and the paper exit unit
    • Konica C6000
      • Oct 2022
      • 9
      Hello!
      I checked the circled units. The print setting is face up.
      It very rarely prints without waves, but usually there are 2-3 waves in the sheet.
      • tech51
        • 846
        The entry guide to the fuser with the brown looking coating on wears and can cause this.
        • Konica C6000
          • Oct 2022
          • 9
          Do you think about the lower fusing roller?
          I have a piece of them, i will replace tomorrow.
          Thanks!
          • joaopauloooo
            • 46
            Check if the Adhesive tape of the Teflon tape is worn.
            The part you should be looking for this is the "Fusing separation assembly" Part number: A1DUR74H00
            Papel Saindo Ondulado - Konica PRESS C6000 - YouTube
            Another thing that could cause this is humidity, try to see if it happens with low humidity paper.
            • Synthohol
              Certified Konica Expert
              • 5846
              check these gears too, there are one way gears and can crack or slip.
              • Toxic
                • 698
                If you have finisher connected to machine try to open door during printing and check at what section of process paper get wavy, could be finisher problem.
                • Konica C6000
                  • Oct 2022
                  • 9
                  Thank you all for your help!
                  Yerterday a replaced the lower fusing roller, and the problem is solved. I checked the gears too.
                  • allan
                    RTFM!!
                    • 5462
                    One of the one way bearings on the fuser exit get installed wrong way round and has the same result.
                    Whatever
