IU610 convert to IU612
  • Toxic
    • 698
    Hey guys,
    Does somebody try this convert, i have situation that i have in stock OEM IU610m and i need IU612m for C452.
    I work on this series long time ago and never tryed to refurbish, only do complete OEM replacement.
    Now one C452 appear with magenta problem and new IU612 is to expensive to order for so old machine and i would like to try to use this iu610 if possible.
    By the looks of it OPC is the same but even better will be to put in complete unit, just replace chip.
    What is my options?
  • pickle8486
    • Aug 2013
    • 26
    Re: IU610 convert to IU612
    Honestly I don't think the drum units changed from the c451 series to the c452 series other than the chip. Obviously the old chip will have to be used. So it will show as a used IU not a new one
    Sent from my SM-N986U using Tapatalk
    • escalante
      • Sep 2018
      • 115
      Originally posted by Toxic
      Hey guys,
      What is my options?
      I use the UI610
      1.- Cylinder
      2.- Blade
      3.- Charge crown
      4.- Developer
      5.- The hubs and beaters
      6.- Gear set
      For Bizhub C654e and it works perfectly.
      Enviado desde mi Infinix X693 mediante Tapatalk
      • Toxic
        • 698
        So the complete unit iu610 will not fit in C452?
        edit:did not see you mention C654
