4750 firmware
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    4750 firmware
    Only have 2 of these "Lexmarks" I work on. I know you have to install firmware in order, 899.pr (sub) then 999.prn (main) but what about installing other FW, can you do this anytime after installing "sub" & "main" firmwares first?
    Thanks in advance
  • avecosat
    • Jun 2012
    • 305
    Re: 4750 firmware
    5.2. Installation procedure to update a firmware
    Please install the new firmware in the following order 1 - 3. If not, MFP will stop recognizing USB cable.
    1. Engine Firmware [A6F750G0501-999] or later
    2. Sub controller firmware [A6F730G0850-899] or later
    3. Main controller firmware [A6F730G0850-W99] or later
    This is the correct way
