Konica bizhub PRESS C6000 Dumping Cyan
  • joaopauloooo
    • 46
    Hello,
    I'm having an issue on this KM C6000, under high humidity it starts dumping so much cyan toner I had to revert the toner density.
    Already changed the corona, witch by the way was new, and same thing happens. Swapped the drum unit and still the issue.
    Also noticed that the readings on humidity are not right, could this be the problem?
    Machine has a PF-602 installed.
    313377222_10160611778827193_6932819759697575431_n.jpg313361334_10160611779632193_8389959741603722005_n.jpg313365147_10160611560322193_3167385954530460940_n.jpg
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Konica bizhub PRESS C6000 Dumping Cyan
    swap the cyan and magents DV units and see if issue stays with cyan or its another problem.
    put tape over the holes when swapping and leave the toner door open while testing so it wont try to add toner.
    • tulintron
      • Jul 2014
      • 668
      Originally posted by joaopauloooo
      Hello,
      [ATTACH=CONFIG]55214[/ATTACH][ATTACH=CONFIG]55215[/ATTACH][ATTACH=CONFIG]55216[/ATTACH]
      In the first image you wanted to show an A4 sheet completely covered in cyan?
      I noticed that there is no white border on the sheet.
      If your answer is YES, your problem is related to the cyan charging corona assembly. Corona, connection, fitting, HV board, something in that reasoning.
      Moisture wouldn't do that.
      • joaopauloooo
        • 46
        Yes to all.
        Thanks.
        • joaopauloooo
          • 46
          Repleaced the Drum and the issue is gone for now.
          • Sysco
            • Mar 2010
            • 43
            Change the drum, corona, develop house, and see the result.
            It's not too much time.
            • L0rdC
              • Feb 2021
              • 82
              seen on a c6500 two weeks ago, also on the cyan, the corona wire is burnt, if you swap crowns the problem will go to another color, change the corona wire
