"the optical photoconductor needs to be replaced" message on c558 with apple
  • adecanmin
    • Oct 2010
    • 322
    Gentlemen.
    I have the warnings turned off on the copier. I told the customer to ignore it but it would be nice if there is way to remove that message. I've read a bit about it and it looks like an issue with the mac drivers. Just want to be sure I'm not missing something.
  • allan
    RTFM!!
    • 5462
    Re: "the optical photoconductor needs to be replaced" message on c558 with apple
    You could disable the SNMP protocol I think.
    Whatever
    • adecanmin
      • Oct 2010
      • 322
      Ok. Should it be done on the copier interface side or the print driver portion?
      • rrrohan
        • Sep 2011
        • 1977
        copier side.
        if you dont want it to effect the Windows PCs you could just change the SNMP name from Public to something else.
        • adecanmin
          • Oct 2010
          • 322
          Originally posted by rrrohan
          copier side.
          • tsbservice
            Field tech
            • 8064
            Gentlemen.
            There are at least 3 places in CE mode to enable/disable consumables messages, plus soft switches 227 and 230.
            • D Colour
              • Oct 2008
              • 217
              Im pretty sure its the software switches hide that message on Macs etc. Machine needs function v3.3 or newer.
              To hide consumable life
              Switch 227 Hex 80
              Switch 230 Hex 08
              Set hex back to 0 to display.
              Bizhub C358 missing 'Device Comsumables' tab
              Everything that has a beginning, has an end.....
              • adecanmin
                • Oct 2010
                • 322
                Switch 227 Hex 80
                Switch 230 Hex 08
                I changed 227 but not 230.
