C450i J30-03, 92-01, 99-01
Re: C450i J30-03, 92-01, 99-01
With oddball errors I usually start with making sure the firmware is up to date. it has fixed some stuff that is seemingly unrelated. You may want to start there. -
Yeah, sorry forgot to mention that. I had flashed firmware on my first visit. Agreed, whenever I have weird codes I flash firmware, either reflashing the same level if at the current level already or upgrading to the current level.Comment
While the jam codes are different, I could see the pickup roller oneway issue potentially causing a 99-01 from the bypass. Might be worth a check.
i-series_bypass_oneway.jpgA Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
