C450i j9901
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    C450i j9901
    I have a problem on a C450i. Every 20-30 prints it jams with the code j9901. I have changed the register clutch and the fuser, but it doesn't work. I have checked the free movement and return of the registration sensor actuator and the paper loop sensor actuator before the fuser and there are no faults.
    It happens from both drawer 1 and drawer 2. Any ideas?
    Thank you very much.
    Field technician since 1994
  • Gift
    • Mar 2011
    • 2459
    Re: C450i j9901
    Try and disable the media/thickness sensor
    • elmaligno
      • Oct 2009
      • 302
      Re: C450i j9901
      It has been disabled yet
      • Gift
        • Mar 2011
        • 2459
        Re: C450i j9901
        OK, how's the condition of the feed rollers? What's the total counter saying? I've noticed that some paper brands (especially navigator) has sold some really bad batches of paper causing jam+timing issues so in case of doubt it's worth testing another brand you can trust. Have you visually checked the spring of the reg-sensor actuator? It is possible that it works even if the spring fell of the hook but it's movement is too laggy.
