Firmware Update - C224
  • dustybrush
    • Nov 2022
    • 2
    Good Morning Ladies, Gents and other inclusive titles.
    Having an issue with our C224 (non e) our server updated it's firmware and automatically disable SMB v1, this caused our C224 not to be able to send scans over the network to our folder, manually dropping the protocol back to SMB v1 on the server has fixed this but it is a security issue. Trying to reconfigure the machine from SMB to scan to e-mail didn't work either even with allowing less secure apps turned on which I believe is a security certificate issue due to old firmware.
    Is there a firmware update that allows SMB v2 and that rectifies Gmail connectivity issues.
    Happy to contribute, if someone can help me acquire the latest firmware.
  • Kenny
    • Jun 2009
    • 536
    Re: Firmware Update - C224
    it will need special firmware, Version Up Firmware Technical Information Rev4-2.pdf
    • copier tech
      • 8221
      You can update you C224 (non e) using the 'version up firmware' this will give you SMB v2 etc.
      We can supply this for you.
      Printer Firmware
      Version Up Firmware Technical Information Rev4.pdf
      • dustybrush
        • Nov 2022
        • 2
        Printer Firmware
        [ATTACH]55282[/ATTACH]
        Thank you for this, very helpful. Do I purchase through the site?
        • copier tech
          • 8221
          Thank you for the order.
          Let me know how you get on.
          https://mega.nz/file/dU8yRA7B#tjpsk8...HY2bbBuhrj9kaw
