Bizhub C360i, parallel lines on color copies
  • Manro
    • Nov 2022
    • 8
    Hi Friends,
    We have a new bizhub c360i, averything is fine except color copies,there are blue or red parallel lines no color copies as shown on attachment, on black copies, printing and scanning everything is fine. Do you have any ideas how to fix it?Capture.jpg
  • jwai
    • May 2018
    • 517
    Re: Bizhub C360i, parallel lines on color copies
    Performed installation procedures properly?
    • Manro
      • Nov 2022
      • 8
      yes
      • tsbservice
        Field tech
        • 8052
        Originally posted by Manro
        yes
        I would say no as those lines are well known to be consequence of uncompleted initial setup.
        Do you have a paper guide with install instructions in the box?
        • Manro
          • Nov 2022
          • 8
          Yes, installation instructions are folowed step by step
          • avecosat
            • Jun 2012
            • 305
            +1 Follow step by step install manual
            • tsbservice
              Field tech
              • 8052
              Stop + 3 was performed?
              • Manro
                • Nov 2022
                • 8
                I do not understand
                • rrrohan
                  • Sep 2011
                  • 1977
                  I do not understand
                  not a good sign. you say you followed run up guide so this should make sense to you
                  also you need to set the time in that menu even if its correct
                  • Manro
                    • Nov 2022
                    • 8
                    I think everything is ok, all of the function work well, when I scan documents then I print in color there are no line, but when I copy the same document in color there are the lines (blue or red).
                    • rrrohan
                      • Sep 2011
                      • 1977
                      but did you do the run up. sounds like simple case of lines of shame aka runup not done correctly. and the fact u dont know the stop 3 key sequence indicates you havent done the runup correcty
                      • Manro
                        • Nov 2022
                        • 8
                        Maybe not, How to do the run up?What is the stop 3 key sequence?
                        • Kenny
                          • Jun 2009
                          • 533
                          bizhub C250i C300i C360i Installation Manual.pdf
                          follow the installation procedure correctly! i would suggest looking at step '13'
                          • rrrohan
                            • Sep 2011
                            • 1977
                            https://1drv.ms/b/s!AihlUvuCMZ5jgYYn4Vn-KxViXFgJuw?e=B7unQG
                            oh your 4 series. stop 3 is 8 series on. did you do the stop 1144 Clear?
                            • Manro
                              • Nov 2022
                              • 8
                              I 'll follow again all the step mentioned on the book, would you explain more ''oh your 4 series. stop 3 is 8 series on. did you do the stop 1144 Clear ''
