press c1200
  • romario
    • Jun 2020
    • 193
    press c1200
    hello group, someone with experience in press c12000, I have this problem when printing paper size 33x900 the part of the print queue moves, change second transfer, registration unit, paralyze the copy before it went to transfer and notice that the paper enters perfect to the registration unit and the image on the transfer belt is perfectly aligned without warping. here attached image for you to see
    on paper size 33x48 it still comes out deformed but minimal, while the paper is longer you don't notice the fault anymore, on paper from 90 grams to 200 grams they come out fine, the fault is noticeable in 250 grams to 400 grams
    thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5892
    Re: press c1200
    what is 33x900? thats 1.3" x 3' thats a ribbon.
    anyway, i would first run the both sides adjustment in the manual.
    its under image position adjustment.
    • romario
      • Jun 2020
      • 193
      Re: press c1200
      excuse me 33cm x 900cm banner. all centering adjustments both sides have been made
      thanks
      • tulintron
        • Jul 2014
        • 668
        Re: press c1200
        If you confirm that the paper arrives correctly in the register, the problem is in the writing. (Remember that there is mechanical positioning).
        If you confirm that the writing is correct on the transfer belt, the problem should be with the paper.
        Something is happening and you haven't noticed.
        If centering adjustments are all ok, try performing Belt Line Speed and Skew Adjustment.
        Test the 13'x19' in other trays and compare if the error is the same as in the banner tray.
        You said that at lower weights, it appears less.
        Have you tried to print 250 gm banner as 75 gm and see how it looks?
        Something different has to show
        https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
        • romario
          • Jun 2020
          • 193
          Re: press c1200
          hello. If I went back to the client and checked the fault, I get from 90 grams to 400 grams, size 33cm x 90 cm in 13x19, it also moves butt, the iq corrects, but in 33cm x 90cm it doesn't correct anymore because the displacements are a lot this week I'm going to change the unit transfer. and I will tell you.
          thanks
