bizhub 754e B/W
  • rame
    • Nov 2022
    • 3
    [Misc] bizhub 754e B/W
    Hello.. the adf is outputting multiple sheets of paper together while copying bizhub 754e..
    I changed the upper and lower pulleys but no change... Please what is the solution..
  • Gift
    • Mar 2011
    • 2459
    Re: bizhub 754e B/W
    You can try and mod the exit area with some sort of "feeler" hanging from the top but it probably won't help if the originals are too "wobbly".
    Another thing you can try is to scan the originals SEF and see if this works better.
    I don't know if KM offers some sort of "silent" mode to reduce the speed wich probably would help reducing your issue.
    • tsbservice
      Field tech
      • 8013
      Re: bizhub 754e B/W
      Double check your separation roller install.
        • 23008
        Re: bizhub 754e B/W
        +1 on that. It's very very easy to get the separation spring folded over ... not on it's post. Ask me how I know. =^..^=
        • tsbservice
          Field tech
          • 8013
          Re: bizhub 754e B/W
          You know everything about copiers my friend but the greatest secret we know is nobody is perfect.
          • allan
            RTFM!!
            • 5462
            Re: bizhub 754e B/W
            There is a pressure adjustment that has like 3 settings or continuous on some you can play with too. The sheet metal in that area can bend, that will give you endless hell.
            Whatever
            • rame
              • Nov 2022
              • 3
              Re: bizhub 754e B/W
              Where are these boards that I can bend in that area? Can I have a picture please
              • rame
                • Nov 2022
                • 3
                Re: bizhub 754e B/W
                • allan
                  RTFM!!
                  • 5462
                  Re: bizhub 754e B/W
                  The metal plate the separation assy is mounted too. No images can not help you with that.
                  Whatever
