C450i + FS-533 + PK-519
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    I have a c450i with FS-533 and PK-519. It jams all the sheets in the PK, with jam code J72-70, which indicates jam in the PK.
    The thing is that I have put that PK in another copier and it works fine, I have put it with another FS-533 and it also works fine, but when I put it back in the C450i, it does not pass any sheet, it jams with the code j72-70.
    That is to say, I have already changed the FS-533 on which the PK depends and it jams, but in another machine, it always works fine.
    The c450i has correctly activated the PK in service mode, and the furmware updated.
    In short: Any FS-533 + PK-519 jams me in the C450i, even if I'm not punching, just passing the paper. But on any other copier, it doesn't fail.
    Any ideas?
    Thanks.
    Field technician since 1994
  • tsbservice
    Field tech
    • 8053
    Re: C450i + FS-533 + PK-519
    Colleague has something similar on another machine think it was C227, nevertheless it turns out salesman didn't purchase option kit for this combo of finisher and punch kit. I would double check configuration documents on this model.
    • elmaligno
      • Oct 2009
      • 302
      Thanks but they are ok, MK necessary is installed.
      • tsbservice
        Field tech
        • 8053
        So problem stays with that machine not with FS or PK(which are working on another machine)?
        Maybe you can see if downgrade of firmware will change something?
        • tech51
          • 846
          I had this a couple of weeks ago on c450i. I came to the conclusion it was a timing error between the main body exit and the finisher. I ended up lubricating the main body exit roller bushes and the code didn’t reappear after a long test whereas before it was nearly every print.
          Might be an idea to try this and let us know if it helps or if I just got lucky.
            • 23010
            On the larger Konica Minolta finishers there is a calibration for the paper sensors in the punch. If there is a similar calibration, you should see it in the setup manual.
            It appears that the FS-533 is compatible, requiring the MK-607 fan kit.
            I did not see a calibration setting for the FS-533 or PK-619. On the production Konica engines, it will come up as Finisher Adjustment > Stapler (Punch) Adjustment > Paper Edge Sensor Adj.
            I don't know if that helps or not. =^..^=
            • trscolin
              • Aug 2012
              • 21
              There are some different versions of the FS533. Recent C450i came with A2YUWY3. 8 series with WY2
              Maybe something to check.
              • copyrooks
                • Oct 2013
                • 210
                There's a konica knowledge base article regarding the fs 533 and pk 519 with that exact jam code. Turn on engine dipsw 15 restart copier and test. Had to so this to three copiers with this ongoing code. Good luck
                • elmaligno
                  • Oct 2009
                  • 302
                  I cannot find it, cand you send me that knowledge document?
                  • tsbservice
                    Field tech
                    • 8053
                    You cannot find it because it's not in European knowledge base but in US one. Different story. I believe our American and Canadian friends have their own R&D support team and don't rely only on KM engineers in Japan.
                    We have to work hard just to find something is already invented
                    • emujo2
                      • Mar 2017
                      • 1579
                      • elmaligno
                        • Oct 2009
                        • 302
                        That was the problem. Thank you all.
                          • 23010
                          This was common on the xx8 series with the FS-533. It only jammed when the finisher was attached. The way we figured it out was that the heavy media (Thick2) which feeds out slower did not jam. The exit bushings were nearly seized. =^..^=
                          • tech51
                            • 846
                            • Gift
                              • Mar 2011
                              • 2459
                              Thanks a lot, I think this did just fix that issue for us, too - colleague was visiting a C550i (with FS533 + PK519) and same jam code.
                              Luckily google works fine with searching CTN after relaunch by now LOL
