Konica c368 function will not work scanner unavailable
  • DOE
    • Mar 2010
    • 258
  • tsbservice
    Field tech
    • 8052
    Re: Konica c368 function will not work scanner unavailable
    Go in service mode and check last error codes logged. Scanner unit may be isolated due to an error.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4764
      You posted "it's possible I might have changed the setting". Don't think there is anything in admin or serv modes that would isolate scanner, except "isolation set" in service mode.
      Anyway go into service mode, "system 1", "problem unit isolation set" and "unset" scanner or ADF. If code comes back you will have to look at malfunction.
      If all else fails you could backup data and initialize machine in service mode. This will clear all settings.
      • emujo2
        • Mar 2017
        • 1579
        Your machine has experienced a fault that will allow you to continue to use it, but the affected system(s) must be isolated. I'm assuming you have more than 1 person in your office and that person is the one that saw the original message saying "scanner error detected, to bypass this feature press (some key)". This isolates the problem and allows other features to work ie fax/print, scan from glass, non sorted copies. Once you cycle main power the machine will go through the process again. This can only be resolved by fixing the issue and restarting. This is different than going into service mode and bypassing a feature. E
