C224 Scan to Email Issues, Ping Failed
  • Jadel Labradoodle251
    • Nov 2022
    • 42
    My C224 model, with firmware successfully upgraded to become the "e" model still cannot send scans to my Gmail. I followed all guied and decided to ping test her, it states "ping failed", I have tried Gmail address, googles IP addresses and even outlook and office 365, still nothing. I can print from her online, the whole website with Admin settings works too, can print from my phone aswell. Anyone know what the issue could be?, I have triple checked that all my info is correct, so why can't she ping ?
    FW Version 3 ( takes a bit longer to start but thats understandable )
    • 14761
    Re: C224 Scan to Email Issues, Ping Failed
    I've had the 4 series machines stop scanning to email and resetting the network adapter almost always solves the problem. Open the web interface from you computer, go into administration settings and reset nic from there. If that is unsuccessful, go into service mode and initialise network settings. Don't do a full data clear!
    Then re-enter network information on web interface.
    Hopefully this helps
    • Synthohol
      Certified Konica Expert
      • 5840
      DNS set one to 8.8.8.8
      • emujo2
        • Mar 2017
        • 1579
        Your C224 did not need to be updated to allow scant to Gmail (Gmail only)..But if you can't ping SMTP.GMAIL.COM, or 172.235.115.109, then you need to trouble shoot this as a network issue..PING is not the same protocol/port that actually using scan to email is. Ping the router and another device from the MFP, if both pass and you can ping the GMAIL IP adress, then it's a router issue. E
          • Nov 2022
          • 42
          Well it worked...kind of since the ping now works but I cant log onto page scope, tried even using a different IP address but I'm getting a new error now called " Data Transfer Interrupted", any clue what could be causing this now?
          • DK-tech
            • Apr 2021
            • 25
            Google no longer supports scanning from mfp like previous. I did find this wich you can try though Yes, you CAN USE GMAIL with a scanner!!! Here'''s how to set it up: : msp
