C250i fusing problem
  • femaster
    • May 2011
    • 1514
    #16
    Re: C250i fusing problem
    This is all I can dig up on this subject. I don't believe this has been shared before, so here goes.
    Offset image from fusing unit
    Known Error
    Related Products:bizhub 300i, bizhub 360i, bizhub 450i, bizhub C250i, bizhub C300i, bizhub C360i, bizhub C450i
    Error: Image is offset from fusing unit.
    Root Cause
    Foreign matter adhered to the surface of the thermistor chip inside the heating roller temperature sensor.
    It is highly likely that this occurred because the resistance value decreased.
    Workaround/Fix
    Confirm the heating roller temperature sensor.
    Please review the attached, "How to check for the Heating roller temperature sensor problem" document.
    For a counter measure review bullet # 3 in the attached, "Off set image for unit" document.
    • tech51
      • 846
      #17
      My latest information says to try setting fuser temp to +10 and turning off smart fusing control in Tech Rep.
      • B0265
        • Jan 2007
        • 718
        #18
        Originally posted by NickHilner
        Hi Jwai
        We had exactly the same problem. We swapped the Belt and Pressure roller and Lamp from working fuser and still black wouldn't fuse and colours were fine.
        We replaced the Themistor and seems like it is working now.
        Where do you buy the thermistor/temp sensor?
        • elmaligno
          Expert technician KM
          • Oct 2009
          • 302
          #19
          A7AHM50400 Humidity sensor
          Field technician since 1994
          • Gift
            • Mar 2011
            • 2459
            #20
            Thanks for sharing the bulletins @femaster - can't recall we dealt with that yet but who knows what happen in the future.
            • B0265
              • Jan 2007
              • 718
              #21
              Thanks, but this is what I'm looking for.
              • tsbservice
                Field tech
                • 8020
                #22
                [ATTACH=CONFIG]60560[/ATTACH]
                Only AliExpress I think.
