AccurioPress c3080
  • CopyTech03
    • Jul 2020
    • 55
    [Misc] AccurioPress c3080
    Customer bought this machine online with numerous finishing options. The manual does not list which order to set them up. They are currently set up in this order after the main body: RU-518, IQ-501, RU-510, GP2, RU-510, LS-506, SD-506, and FS-532. It shows the first 3 options and then nothing after that. Does anyone know if this is the correct order and something not plugged in or if this order is incorrect?
    • 23010
    Re: AccurioPress c3080
    I've never tried to string all these finishing options together.
    Does your manual page look like this?: =^..^=
    • CopyTech03
      • Jul 2020
      • 55
      I saw a different page but similar. According to this I should have the accessories in the correct order. Must have at least the GP-2 not connected properly.
        • 23010
        Let us know what you find. =^..^=
        • CopyTech03
          • Jul 2020
          • 55
          • zayonc
            • Jan 2022
            • 49
            There is a suspicion that the RU-510 after G2 is superfluous
            And we need 2 MK-737
            • zayonc
              • Jan 2022
              • 49
              MK-737_E_2_GBC Punch G2.pdf
              • CopyTech03
                • Jul 2020
                • 55
                There are 2 MK-737 installed. Now I am confused. according to the main manual a RU-510 would be installed after G2, but according to these installation instructions there is no RU-510 installed after. It would just be the next component, which in this case would be the LS-506.
                • zayonc
                  • Jan 2022
                  • 49
                  more or less like this
                  • CopyTech03
                    • Jul 2020
                    • 55
                    Thanks, that was it! Just needed to remove that 3rd RU. Now just need to figure out the jamming issue in the LS
                    • CopyTech03
                      • Jul 2020
                      • 55
                      You helped me out last time with this configuration. Now he wants to add a FD-503 for the post inserter option. Would it would with the current configuration and if so where would it go, or would we have to remove one of the RU in order to install the FD. Thanks
                      • zayonc
                        • Jan 2022
                        • 49
                        FD-503 after G2, LS-506 must be removed. There is also a TU-510, they will like it.
