Olivetti MF 304/ Bizhub C308 Jam 32-01
  • Larhal
    • 609
    Hi All,
    First off I am NOT trained on KM models. Ricoh and Kyocera yes. I have the manuals for the KM C308 and have read through the Jam codes and know that the Jam is at a misfeed at exit section.
    Question is there a simple solution to fix this before I go out to the site? Any hints and suggestions on actions to be taken or parts as spares would be appreciated.
    Thanks in advance for your assistance.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • and
    • Oct 2011
    • 97
    Re: Olivetti MF 304/ Bizhub C308 Jam 32-01
    Originally posted by Larhal
    Hi All,
    • Larhal
      • 609
      Originally posted by and
      [ATTACH=CONFIG]55731[/ATTACH]
      Thank you for your input, Going in the morning and I will post my findings and results.
      Larhal
      • Larhal
        • 609
        Hi All,
        Went out to the site and they explained that it was randomly happening. I did 3 duplex copies and it jammed outputting the first side of the duplex page.. Open up and found that the paper was stopped before the transfer belt but the ADU was empty. Checked the sensor outputs for PS40 and PS41 and they worked ok.
        I cleaned all the paper paths, cleaned all the rollers with Platencleen. closed it up add tried again X3 times. Worked OK. Checked the rollers again and noticed that the ADU had unlatched when I opened the cover. I secured it but found that when I went to close the side cover it had popped open again. Seems like the spring tension on the latch was week. Could that be the problem as there was not enough pressure for the feed rollers to work in the ADU? I know there is pressure from the transfer roller assembly pushing back against the ADU but is that enough?
        We will have to see if the cleaning made a difference, if not I will get the parts to repair the ADU.
        More to come.....
        Larhal
        • Larhal
          • 609
          Hi All,
          Well the 32-01 Jam has continued.
          Was out to the site this morning and the only thing I found is that if you press the right hand door in at the top the jam doesn't happen.
          I checked the latch and found where the upper latch engages is a plastic tab. Not very strong. When the door is closed the top forward corner of the right hand side protrudes out some.
          Has there been a retrofit for the right side door?
          Larhal
          • avecosat
            • Jun 2012
            • 305
            The 32-01 is a problem with the SD3 solenoid, it does not work and the paper comes out with only one printed side.
            • Larhal
              • 609
              Thank You Avecostat, That is the exact symptom it is doing. I will order the SD3 solenoid and replace it.
              Your help is much appreciated.
              Larhal
              • Larhal
                • 609
                Hi All,
                Installed the SD3 solenoid and have not had a reoccurrence of the 32-01 Jam.
                Thanks all who assisted me and especially avecosat.
                Larhal
