konica minolta c253 and c220 series SCANNER in EMAIL
  • enricocopyline
    • Jun 2018
    • 124
    Good evening everyone I have a problem on the konica 253 and 220 series regarding the scanner on email because I can't send emails with ssl protocol on port 465, I also tried off and port 25 but it doesn't work.
    i have smtp that has been upgraded to tls 1.2 or higher and i know this is the problem because these konica series don't handle it anymore.
    is there a way to solve the problem?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: konica minolta c253 and c220 series SCANNER in EMAIL
    just my .02
    when you have an extinct dinosaur copier you need to either upgrade to a machine complying with todays security standards or scan to SMB and attach it with your own email app.
    the latter is obviously the least expensive.
    • emujo2
      • Mar 2017
      • 1579
      I have BH 363s scanning to gmail. SMTP.GMAIL.COM SMTP over SSL port 465. 2FA enforced and using app password. If you can't leave your TLS1.2 requirements you are stuck. E
      • rrrohan
        • Sep 2011
        • 1977
        I put user with old machine on SMTP2GO port 2525 no encryption
