Bizhub c250i Red print comes out orange
  • Morten B DK
    • Feb 2015
    • 8
    Hi guys.
    I'm trying to help out a collegue who has a customer with a quite new Bizhub C250i that cant print Red properly. Red comes out orange.
    No codes or trouble. Calibration finishes without fail.
    Machine is fully updated and calibrated.
    We have tried a full initialization and started over from scratch with installation procedure and calibration. Nothing helps.
    DV box and PCU has been changed.
    If we scan the brochure used in the picture the scan looks normal.
    I have never had a similar problem on a KM working with KM for 15 years.
    Any ideas as how to solve this matter ?
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub c250i Red print comes out orange
    I had a customer tick save ink/toner in Adobe reader cause this
    • Synthohol
      Certified Konica Expert
      • 5905
      Perform the following settings from 1 to 3 in order.
      Note: The red increases by following the order outline below.
      1. On the print settings screen of the printer driver, change
      from [Document / Photo] to [Document] in the item of [Quality] tab > [Image quality Setting]
      2. Change DipSW188 to HEX04. (After changing turn OFF/ON the power switch or setting is not enabled.)
      Function to change red parameters and emphasize color preference
      0x00: Disabled (default)
      0x04: Enabled
      3. On the print settings screen of the printer driver, set following
      Color Balance tab: Set magenta to +3 Image quality tab [ Quality adjustment] -> details -> figure / table / graph] .
      also see the doc attached.
      • sangcom
        • Jun 2009
        • 45
        Hi,
        I've had some experience with this,Customers don't like red.
        This solution can be applied to the i-series.
        Dip SW 153 HEX 40
        Good luck
        • tsbservice
          Field tech
          • 8064
          Originally posted by sangcom
          Hi,
          Dip SW 153 HEX 40
          Good luck
          [ATTACH=CONFIG]55910[/ATTACH]
          That is actually working pretty nice, Thank You for the hint.
          • Earthlander
            IT Specialist
            • Jul 2023
            • 1
            Hi,
            Dip SW 153 HEX 40
            Good luck
            Thanks a million, this has also resolved my issue with red presenting as orange on prints only, copies were fine.
            • ShafaqatBlogger
              • Feb 2024
              • 7
              • Check color calibration.
              • Verify color settings in software.
              • Replace toner cartridges (especially magenta).
              • Clean the printheads.
              • Update printer firmware.
              • Check print quality settings.
              • Perform a test print.
              These things you neet to know
              • Jp@docuflow.ie
                • Nov 2015
                • 15
                Hi,
                Dip SW 153 HEX 40
                Good luck
                This saved my life. The bit switches looked like this 01000000 when correct. Thanks for posting this. I am not very familiar with bit switch settings
