Bizhub 284e
  • patrickjlc
    • Feb 2015
    • 225
    Bizhub 284e
    I know it is an older machine, but has very low count, only 123k.
    My issue is put paper on DF or glass and the scanner will move like normal, and that is it.
    When I got to Job List it shows status Stop Printing and the others queued.
    Did a initialization, clear all data, and same issue. It just moves the scan lamp and thats it.
    Cant print configuration page, demo page or counter page
    Any ideas? Thanks
    Sent from my motorola one 5G UW using Tapatalk
  • kingarthur
    • 1344
    Re: Bizhub 284e
    1st thing i'd check, do any drums needs replacing, i know it's low mileage, but it's still possible....drum count isn't the amount of prints, but if i remember, it's minutes/rotations, so if it's turned on/off a lot, or even just sitting there, it'll go through various calibrations. if it is, you might get away with changing the drums etc to "no stop"
    • tsbservice
      Field tech
      • 8006
      Re: Bizhub 284e
      Like kingarthur said. Remove any life stop settings in CE mode and let it her be happy.
      At this low mileage I bet it's original drum and same drum can last many many more (usually).
      I would print halftone pattern at low and high density and if test prints look right let it be.
      Be aware that those are awesome machines but one should push them to the upper monthly volume and beyond and they will happily respond but keeping them idle will cause any kind of problems.
      Keep us informed
      • tulintron
        • Jul 2014
        • 668
        Re: Bizhub 284e
        Keep us informed
        +1
        • patrickjlc
          • Feb 2015
          • 225
          Re: Bizhub 284e
          Thanks KingArthur and TSBservice, did life stop off and administrator unlocking and machine is back in action.
          Will do it to all the machines I have in stores.
          Thanks again for the help
