C250i Check Consumables Life
  • copyguy69
    • Feb 2016
    • 94
    On the older models (C364e) you could check the drum life status under the Utility settings- Check consumables life - drum status. Can't seem to find that screen on this model. Was it moved somewhere else under a setting? Thanks in advance
    Copyguy69
  • nfw
    • Sep 2022
    • 3
    Re: C250i Check Consumables Life
    • [Utility]
      • [Utility]
        • [Information]
          • [Device Information]
    • tsbservice
      Field tech
      • 8052
      Originally posted by nfw
      • [Utility]
        • [Utility]
          • [Information]
      Not necessarily, some soft switches may be involved depending on the region.
      • copier tech
        • 8200
        Copyguy69
        You need to enable drum consumables option with SW227 HEX 00
        Then, Utility>Information>Consumables
        • ebssolutions236
          • Dec 2022
          • 1
          Users will be informed of time to replace a Toner Cartridge, Drum Unit, or Developing Unit via a message displayed on the screen.
          Also, users can select [Utility] - [Check Consumable Life from photocopier rental] to display the current status of consumables (consumption level) on the screen and check it.
          • copyguy69
            • Feb 2016
            • 94
            Thank you for the info!
            copyguy69
