4020i will not see new toner cartridge
  • emujo2
    • Mar 2017
    • 1580
    [Misc] 4020i will not see new toner cartridge
    4020i, 1st time it has needed toner, new bottle will not clear the message. We don't see anything glaringly wrong, and bottle shows present in other devices.. Is there any kind of admin or service mode toner reset similar to the I series? E
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: 4020i will not see new toner cartridge
    that thing is a wolf in konica clothing.
    amazon has the whole machine for 550.00
    you will probably lose more than that servicing it.
    sorry though, since its not a real konica none of the normal engine dip switches are helpful.
    i am at a loss to assist.
    • jwai
      • May 2018
      • 506
      checked the cam gear on toner cartridge?
      • tsbservice
        Field tech
        • 7973
        Either that or try this.
        Find where is # on touchpad right of display (hint: keypad will light up by pressing Fax on display).
        Press home to be in initial state then open front door and press and hold # for a few seconds, reset menu should pop up( at least on original it will), choose right toner capacity and that is it.
        • emujo2
          • Mar 2017
          • 1580
          This does not work..Thanks anyway. E
