Konica C227 Colour Imaging Unit rebuild
  • jonbonse
    • Jun 2009
    • 730
    Hi all
    Does anyone know where I can get a colour imaging unit rebuild kit (OPC drum, drum cleaning blade, dev and reset chip) for the C227?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4531
    Re: Konica C227 Colour Imaging Unit rebuild
    Originally posted by jonbonse
    Hi all
    The C227 uses same drum, blade, drum chips as the C224. The developer chips are same as the biz "8" and "i" series. All available from many vendors.
    • jonbonse
      • Jun 2009
      • 730
      Excellent thank you
      Does it take same dev beads as c224e?
      • Toxic
        • 694
        I tried once to replace only opc and cleaning blade on DR214K but result was not good, background and grey lines, i assume pcr roller and pcr cleaner is also should be replaced together with drum.
        • tsbservice
          Field tech
          • 7911
          Correct. Full rebuild should include 5 things - drum, blade, pcr, pcr cleaning roller and chip.
