C458 copy/print blank
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Hi all,
    I have a client with a KM C458 who called in that it's only putting out blank pages for both print and copy.
    The first thing I did when I got to their office was print a demo page, which also came out blank.
    I tried updating the firmware and got a C-C155 error for my trouble. That's looks to be a finisher issue, which I assume is unrelated.
    I'll be back on-site Monday, and I'll disconnect the finisher and address that problem, but I'd like some help on diagnosing the blank prints issue.
    Thanks!!
    • 23006
    Re: C458 copy/print blank
    My suggestion is to look in service mode to see if any other errors are stored. I had one particular customer who thought is was beneficial to unplug and re-plug all the connectors that they could find (while live). I would get calls for the finisher error, but knew something else had happened (who knows what?) that started their unplugging. They blew the finisher board several times. =^..^=
    • tsbservice
      Field tech
      • 8007
      PH unit (laser) and its connection to main board is first thing I would check. Have you checked for image ITB or K drum stopping machine midcopy? On a side note - why firmware?!?
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 149
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 149
          OK, some feedback...
          I went to the client first thing this morning and disconnected the finisher. After powering on the C458, which had been powered off all weekend, it started printing from the print queue and all images are fine.
          I asked the client when this started happening and it was after a particular user sent a print job on Friday. Being powered off for an extended period seems to have cleared the problem.
          The finisher will be coming back to the workshop to be hooked to a C258 and re-flashed.
          Thanks for being available over the weekend!!!!
          • tsbservice
            Field tech
            • 8007
            He-he wish we all cure them like this but it really will make some techs unemployed if customers solve problems Thanks for providing feedback.
            • FuserNoob
              Service Mgr, CISSP
              • Jul 2022
              • 149
              OK...one last update on the C-C155 error.
              I got the finisher (FS-534 + SD511) back to the office, hooked it to a C258 and re-flashed the firmware (it took a LOOONG time and had to do it twice) then ran a test booklet - OK
              Hooked it to a C458 an ran a test booklet - OK
              It goes back to the customer tomorrow
              note to self...DO NOT UPDATE FIRMWARE ON c458 and up, without verifying compatible accessories.
