Bizhub 454e Developer issue
  • patrickjlc
    • Feb 2015
    • 225
    Hello, have a 454e with 455k and have a developer issue. Copies very faint and I changed drum and developer and prints came back perfect. Now less than a week later issue is back.
    Consumable life drum shows all whiye and developer shows three black squares.
    Am I missing something? Will replace then transfer belt today with another drum and developer.
    Sent from my motorola one 5G UW using Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4679
    Re: Bizhub 454e Developer issue
    Looks like it's not adding toner and very under-toned. If you look at "state confirmation" in service mode the level should show really low. While in service mode try adding toner in the "Image Process Adj" tab. If that doesn't bring quality back then look at the toner hopper, motor, etc.
    • tsbservice
      Field tech
      • 8007
      Absolutely agree with copyman, state confirmation is first thing I do when image quality is suffering.
      Also check error history for C215X codes, lastly but important you almost always will get screwed by using used developer unit because of different TCR sensor readings.
