Konica/ Olivetti Image units
  • Max
    • Oct 2011
    • 555
    Hi all. Is there a way to make Olivetti branded MF283 to accept Konica original Image unit? Perhaps via a system bit SW? Thank you in advance.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4638
    Re: Konica/ Olivetti Image units
    Only way I think it could be done is change the chip on image unit. Aftermarket chips should work on all models it crosses to.
    • CP-1015
      • Nov 2020
      • 317
      I wonder that you have problems. Does reset not function or will you get an errorcode?
      • Max
        • Oct 2011
        • 555
        Simply get wrong IU fitted message.
        • tsbservice
          Field tech
          • 7986
          Switch 10 should do the work but may get some side effects depending on environment.
          • CP-1015
            • Nov 2020
            • 317
            Is the MF283 with C-287 identical? And it's a colour image unit?
            • CP-1015
              • Nov 2020
              • 317
              The original drum chips from KM C-250i are the same like the original drum chips from Olivetti C-259(identical ?). Are there differnt chips for developer or imaging unit? Can someone please measure the resistance between pin 1 and 4 from orignial Olivetti developer chips, please? Thanks advanced.
              I tested sw 10 by an C-287 without any trouble. But I don't know if there are original chips mounted.
              • techsxge
                • Jan 2022
                • 660
                Hi,
                there should be no issue using C287 Image Unit in MF283. They are the same Machine just rebranded. I can't recall having issues with using KM Parts in Olivetti Machines.
                Drum chip for Olivetti D-color MF223 / MF283 – CopyXpert
                • CP-1015
                  • Nov 2020
                  • 317
                  Originally posted by techsxge
                  Hi,
                  Are there different versions of the 7 series? So my C-287 has colored image units. Drum chips only fit black drum unit. The original question is also about Image Units. Incidentally, it was about original chips.
                  • techsxge
                    • Jan 2022
                    • 660
                    I seem to be lost in what you mean here. Mind to send me a forum private message in German as i see you're from bavaria?
