C224e C258 Separate scan
  • sa43
    • Aug 2016
    • 6
    [Misc] C224e C258 Separate scan
    Hello I was looking for, but without success, where to add this shortcut to the panel in the scanner so that the button would show a separate scan
  • jwai
    • May 2018
    • 509
    Re: C224e C258 Separate scan
    admin->custom display setting
    • Synthohol
      Certified Konica Expert
      • 5850
      utility/user settings/
      7.1.15 Separate Scan from Platen(1) Use• To select whether to set normally continuous scan when scanning the original on the platen glass.(2) Default setting• No(3) Setting range• Yes• “No”
      it appears the application button is missing where your finger is as well from your screen.
      im pretty sure there is supposed to be one there.
      then you can set a program for it if no other options exist.
      • emujo2
        • Mar 2017
        • 1579
        This might have something to do with the need to allow the settings to be changed in adm[Utility]
        • [Administrator]
          • [System Settings]
            • [Function Display Key Permission Setting]
        • Once this is enabled you can move the app from and to the main screen in
        • Utility]
          • [Utility]
            • [Customize]
              • [Function Display Key]
                • [Send/Save
