Web interface not working with Chrome
  • mascan42
    • Oct 2008
    • 480
    I'm installing a C360i and I'm having trouble getting to the web interface. I had to initialize the network settings because the machine was previously a demo somewhere and all the settings were left on it. But after clearing the network settings, I can't access the web interface using Chrome. I can get it using Edge, but the customer primarily uses Chrome. Any idea what the problem could be?
  • tech51
    • 846
    Re: Web interface not working with Chrome
    • tsbservice
      Field tech
      • 7962
      It's not a big deal either Edge, Firefox or Chrome is used. You should initialize all settings not only network, that will make it work with Chrome for customer satisfaction.
      • emujo2
        • Mar 2017
        • 1580
        My guess is a SSL cert was created using the old domain and IP..Clearing the network setting would not remove this certificate. If you can get in with any other browser, turn off SSL, delete the current cert, create a new one, and if necessary enable SSL. E
        • davidmtupper
          • Jul 2021
          • 326
          You will need to enable SSL with the new cert, most new browser will reject a connection to the copier without it. The other option (rapidly becoming a non-option) is to use an older browser like IE if you still have access to it (Win10 and earlier, some early Win11 installations before being updated).
          • Synthohol
            Certified Konica Expert
            • 5793
            Originally posted by Edward829
            In this article, we will explore some of the best toddler table and chairs options available and delve into their uses and benefits for your little one. best folding rocking chair
            I think you eat poop from discarded diapers there bud.
