Bizhub C754e with Fiery black issue
  • Sandoval
    • May 2018
    • 12
    When printing black colors the image is not good. Developing unit is a new, fusing unit, transfer belt unit also, original toners.
    Any suggestions?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Bizhub C754e with Fiery black issue
    run the halftone and gradation test patterns and determine if its an engine problem or physical issue.
    what makes it classified as a Fiery issue?
    what does the fiery demo page look like.
    atdc levels? etc...
    there are also a bunch of fiery color settings like black overprint composite black and the like.
    have you changed the output settings on the fiery?
    so many questions, can the copier produce a solid black halftone test pattern at 255?
    just trying to see if its a fiery issue or a copier issue or even the paper for that matter.
    • tsbservice
      Field tech
      • 8052
      Any suggestions?
      [ATTACH=CONFIG]56694[/ATTACH]
      Hello, black drum unit anyone?
      • Sandoval
        • May 2018
        • 12
        I tried halftone on 255. The problem is the same, so not the Fiery is the problem. Tried different drum units - same.
        • jwai
          • May 2018
          • 517
          image transfer roller?
          • Sandoval
            • May 2018
            • 12
            I doubt, because its only on black.
            • L0rdC
              • Feb 2021
              • 82
              As in any machine, half tone 255 and interrupt printing to see if the drum generates well, as you said that it appears the same when testing another drum, I would bet on the developer unit, counter?
