konica minolta c224e error c-df50
  • zeca
    • Apr 2019
    • 16
    Hello, this machine display the error C-DF50. Help.
    https://t.me/pump_upp
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: konica minolta c224e error c-df50
    3.16.25 CDF50, CDF70, CDFA0 (1) Contents
    Trouble type ASIC image version failure
    ASIC image access failure
    ASIC image error
    Trouble code CDF50
    CDF70
    CDFA0
    Rank C
    Detection timing Communication error is detected between the MFP board (MFPB) and the CCD board (CCDB).
    Trouble isolation -
    Relevant electrical parts • MFP board (MFPB)• CCD board (CCDB)
    bizhub C364e/C284e/C224e K TROUBLESHOOTING > 3. TROUBLE CODEK-106(2) Procedure
    Step Action Control signal Location of electrical components
    1 Check the connector between MFPB and CCDB for proper connection, and correct as necessary. - -
    2 Update the firmware. - -
    3 Replace CCDB - -
    4 Replace MFPB
    you're welcome
    • zeca
      • Apr 2019
      • 16
      Muito obrigado.
