Setting Machine
  • no_bct
    • Feb 2023
    • 37
    [Misc] Setting Machine
    good afternoon seniors
    I have a Sindoh D332E and I'm having problems setting up wireless and direct print. can anyone help me?
  • Synthohol
    Certified Konica Expert
    • 5906
    Re: Setting Machine
    are you using the konicaminolta print app?
    • no_bct
      • Feb 2023
      • 37
      Re: Setting Machine
      already, I scanned the barcode but there was no response to install
      • Synthohol
        • 5906
        Re: Setting Machine
        you download it on the mobile device from the play store or whatever apples use too.
        is the machine hardwired as well?
        if so and the wired and wireless networks are on the same subnet you can manually install by IP in the app.
        there are many solutions more economical and just as reliable at your disposal other than the expensive OEM wireless accessory.
        you can look for direct print or airprint in admin mode too if it exists, its not a KM model# so i havent a clue what you actually have.
        good luck.
        • no_bct
          • Feb 2023
          • 37
          Re: Setting Machine
          good luck.
          We've done it that way, but the machine still can't connect to the application
          • Synthohol
            • 5906
            Re: Setting Machine
            try opening the copiers web page from a browser by IP address.
            compare the IP addresses just to make sure they are on the same subnet.
