Konica Minolta Bizhub Pro 1051 foggy/ghosting
  • hory_143
    • 23
    Hi all,
    i have problem with ghosting, after everything replaced from OPC DEVELOPER,Cleanig Blade,Corona, i have the same issue.
    PLEASE see the attachen photos
  • manuelcorrea
    • May 2009
    • 46
    Re: Konica Minolta Bizhub Pro 1051 foggy/ghosting
    Clean LPH assy.
    • ysshin79
      • May 2017
      • 37
      If the symptoms are the same after cleaning the LPH, the LPH needs to be replaced.
      • BruJtech
        • Dec 2021
        • 5
        IDC sensor .... what Toner are you using? had simular issue with Km H toner
