c253 with code c2152.... pls help
  • tarzak911
    • 55
    hi tried new transfer belt and checked works a while then code come back.. has any one encountered this..
  • copytechman
    • Nov 2008
    • 947
    If you've changed the belt entirely and it's the new style belt (with the new type of sensor bracket) then you need to replace the sensor arm/assy for that part of the machine... not fun, buried in the back behind pretty much everything.. had it happen at least once to us!
    Regards!
    A.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Check out the latest technical info...................hope it helps.
      The gene pool could use a little chlorine.
      • Tata
        • May 2008
        • 42
        What copytechman says is right on. make sure your belt has the new style sensor bracket. If you replaced the sensor bracket yourself, make sure the plate is in the right place. JSC sent you the pdf. In step 4 just make sure you see the plastic before you put the screw.
        • tech51
          • 846
          Ther have been more issues since the "final" solution was issued I have attached the troubleshooting guide for this fault. Hope it helps.
          • JSC
            Gimp
            • Dec 2006
            • 618
            tech51 is correct, i uploaded the wrong pdf. My bag..........
            • masterteknicion
              • 48
              Try leaving the silver levers on the right hand side out. That is don't put the screws in the in the belt lock levers. Just close the right side cover and let the code reset. Once the code resets and you are able to make copies, then you can put the screws back in. See what happens. I have fixed many 2152 code just by doing that.
              Good Luck
              • tarzak911
                • 55
                thank you everyone
                • Promise
                  • Jan 2024
                  • 19
                  Re: c253 with code c2152.... pls help
                  plz can I have the pictures in bizhub c550 that is showing 2152
