C500: toner on drums
  • 21043
    • 63
    Hello!
    when i remove belt i see a layer of toner on the drum surface - is it normal?
    on yellow this layer is biggest, on magenta lighter, on cyan and black there is almost no layer.
    Thank you!
    PS in a highlighted zone on photo there is a lot of yellow toner.
  • mahou911
    • Jul 2008
    • 37
    I had a problem close to this one once. Check out if toner on drum is fused on it or if you can erease it. I had a Yellow drum once that had been fused too long with toner on it and I had to change the yellow drum.
    Also, your blades could be the source of your problems.
    let me know
    • 21043
      • 63
      i can easy wipe it out
      • texchar555
        Senior Production Tech
        • Mar 2007
        • 142
        when was the last time the drum cleaning blades replaced? and how was the transfer belt? one more thing what about the toner waste filter?
