Image quality issue Bizhub C658
  • JasonSBE
    • Apr 2014
    • 186
    I'm already sending a tech out in the morning to swap the HV board and DC contacts, but I wanted to put this up here in case there's something else we should be looking at.
    The machine presented with image quality issues last week. We swapped the K Developer with one from another machine for testing purposes. It cleaned up and was working right. Now the issue has returned. Same image quality and same symptoms. My tech didn't check the Table values in state confirmation. I ran out there today and noticed that the K values are abnormally high. I put in a new drum and tried to calibrate to see if it would come down, but it didn't really improve. I set the background image density to 5 for K and that has helped the image quality but not the underlying issue. We're going out tomorrow with a new OEM developer, a hv board, and a dv contact assembly in the morning.
    It isn't letting me upload the pictures of the VDC and VG values. Files prolly too big.
    Before new drum/gradation adjust:
    Plain Paper:
    Vcd-c 338
    vdc-m 350
    Vdc-y 452
    vdc-k 800
    Vg-C 488
    Vg-M 505
    Vg-Y 352
    Vg-K 800
    After new drum
    Vcd-c 372
    vdc-m 399
    Vdc-y 407
    vdc-k 771
    Vg-C 522
    Vg-M 554
    Vg-Y 557
    Vg-K 996
  • Brad6784
    • Mar 2015
    • 77
    Re: Image quality issue Bizhub C658
    [ATTACH=CONFIG]57267[/ATTACH]
    Plain Paper:
    Vcd-c 338
    vdc-m 350
    Vdc-y 452
    vdc-k 800
    Vg-C 488
    Vg-M 505
    Vg-Y 352
    Vg-K 800
    After new drum
    Vcd-c 372
    vdc-m 399
    Vdc-y 407
    vdc-k 771
    Vg-C 522
    Vg-M 554
    Vg-Y 557
    Vg-K 996
    That looks like an issue with the toner, is it OEM toner or compat? If it was a toner issue, that would also explain why a replacement dev unit cured it for a little while. I would take a new toner, fit it and run sky shots to clear the hopper (or vac it out) and then fit a new dev unit.
    Good luck.
    • tsbservice
      Field tech
      • 8019
      Never ever trust used good known developer unit. Period.
      Especially black is so cheap to do experiments with.
      K voltages are extremely high.
      Go for new one. Stock it.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4712
        That sample is classic example of developer unit being depleted of developer. I swap developer units from other machines all the time with no issues so think you are on right track with HV pwb. Usually when I have a machine producing a sample like that I put new drum and either a used dev unit or add aftermarket developer to existing dev unit. If dev unit life is at 25% or less I will replace with new unit. Especially the black since like tsbservice posted they are so inexpensive.
        Also agree with Brad that aftermarket toner could cause issues.
        • JasonSBE
          • Apr 2014
          • 186
          Thanks all for the solid tips. The toner may not be OEM. We have been trying to get back to all OEM toner but some sites still have compatible. I'm gonna have my guy check. I know swapping devs is not a good idea, we just didn't have any available at the time. We've had them on order for over a week. Thankfully we're supposed to be getting some tomorrow. I'll try the toner first, and if it's compatible we will vacuum out the sub hopper and try to bleed out the other toner. If it doesn't clear up we'll change the dev. It already has a new drum. If the numbers are still sketchy, we'll try the dv connections and hv board.
          • rrrohan
            • Sep 2011
            • 1977
            if i see non genuine toner spares at customers that we supplied during the shortage i just bin them as the supplier we used atleast were killing devs and even drum (leaving weird sticky residue on them)
            id vote genuine toner after cleaning hopper and new dev
            • copyman
              Owner / Technician
              • Sep 2005
              • 4712
              I'm also cleaning up the mess that Konica Minolta put us into with the toner shortage last year. After many years of educating my customers to use only genuine toners I had to sell them aftermarket during the shortage. Now trying to get all my customers back to genuine. So far I've been lucky with only a few machines affected by crap toner. I'm still pissed at Kon/Min. If I wasn't so close to retirement I would have switched OEM's, that's how mad the toner and machine shortage made me !!!!
