For those wanting to move User Boxes between devices - I've had some success using this method - doesn't seem to want to move any with any contents in
Admin mode - Security setting- page2- Maintenance mode access - set to allow
Service mode- System 2 - page 3 - Maintenance mode - set to effective
an extra button pops on on the bottom left in service mode - machine update settings - select it, then machine auto update settings - machine export settings, highlight what you want to export, but from experience everything is selected, so deselect what you don't want
enter password and start
to import, as above, but depending on function/FW version there is a button Machine import settings - if you don't see this button, update FW and function version
to go into maintenance mode on the i series, go to admin then security - security details - maintenance mode
When you have finished, the device will still be in "Maintenance mode" even after rebooting - there'll be a big arrow at the top left of the screen - press it then exit
maintenance mode
maintenance mode
