Eeprom reset c652
  • hooman23
    • Jul 2014
    • 57
    Eeprom reset c652
    Is it possible to install c452 eeprom on c652 machin? Is it necessary to reset eeprom. How can i reset eeprom? Is it possible with farmware rewrite? Possibl with A0P00Y0-F000-GQ7-D1 version.?
    Can someone explain the process . Thanks
  • emujo2
    • Mar 2017
    • 1579
    Re: Eeprom reset c652
    Wow, the lengths some will go...
    • hooman23
      • Jul 2014
      • 57
      How far you meant?
      • Synthohol
        Certified Konica Expert
        • 5846
        are you looking for instructions how to install it or the file which you should already have.
        • emujo2
          • Mar 2017
          • 1579
          Originally posted by hooman23
          How far you meant?
          No I meant exactly what I said..it is amazing just how long some will try to keep their ancient machines running..20 years ago, I had a UV light, and EEPROM burner and a deskfull of blank EEPROMS. Then every manufacturer went to some type of drive that could update firmware, even still I kept the old abacus around just in case. Over the next few years it got dustier and dustier, the company issued new (win2k) laptops and Presto!! you could no longer use the EEPROM burner. Instead of calling the company to complain that they did not have sufficient support for my 10 year old tech, I did the next best thing, threw it in the dumpster and told all of the techs that if they had a problem needing a EEPROM they were to call sales and upgrade. You are in the same boat, throw this away and you will save many hours of frustration trying to repair the mess you are about to make. E
          • hooman23
            • Jul 2014
            • 57
            I know how to install firmware. And how to replace eeprom.I wanted to know is it realy neccesery to rewrite the firmware that reset nvram. And i wanted to know is it possible to install c452 eeprom on c652 machin?
            Which firmware version reset eeprom? The version that i mentioned above that i have just resets nvram?
            explanation replacing eeprom needed. Thanks
            • hooman23
              • Jul 2014
              • 57
              Thats because you are so special. Im happy for you. Let me gather the infornation that i need.
